Starting problems
Row
Evergreen, CO
Just recently put in a Taurus fan and new Griffin radiator. Every time I would drive it, I would put the fan on high, which I think, drained my battery. I got tired of jumping her, so I decided to put in a new Exide Orbital battery. After I put in the battery, it would crank over but would not start up. It's got a SBC and fuel injection. Any suggestions.
I don't get the nevermind thing??? If you aren't running the fan on startup, and the engine is cranking over while you turn the key, it's either gotta be air, fuel, or spark. Am I wrong?
It would seem to me that if it's cranking over but not starting, that you are without spark, unless you're completely out of gas. Are you completely out of gas? What does the guage say? I'm not sure if I'd trust the guage. You could try and listen to the gas slosh around in the tank while someone else rocks the truck back and forth to tell if you actually had gas.
The truck ran before you put the new battery in, right?
Is there any chance that you bumped the distributor and the clamp is loose and the timing is so far off that it won't start?
I'll step in here since Row is my buddy and he's pretty new to cruisers. The SBC is from an 85 caprice cop car, and the EFI I believe is from a 90's model suburban. His old battery was not very new and not great to begin with, so adding the Taurus fan setup I think was the final nail in it's coffin. The new battery is an Optima yellow top IIRC. How many fuses are under the hood of this truck with this SBC + EFI setup? Anybody know?
How does your amp-meter read? If it's in discharge when you have the fan on and the engine running then you should look to either a new alternator or to a less power hungry fan. If the amp meter is reading 0 or charge then your battery is probably bad.
jjhancock said:
The battery is cranking fast... surely fast enough to start the motor, and a hell of a lot faster than the old one ! I'm really starting to think that this is a blown fuse.
My 93 GMC had a similar problem, not after a battery swap. It turned out to be the ignition module. $$$ IIRC
BTW The nevermind thing was before I discovered this forum software will let you delete a post.
yes check the fuse, had a buddy that the same thing happened... he went and changed the coil, and come to find out all it was was a fuse.
