Starting problems
hard to start? more info....does it crank and not fire? does it turn over slowly?
All it does is turnover a bunch and not actually start, and its not the starter or the battery, I've replaced a lot on my cruiser and this is the only problem that hasn't been solved.
Does your carb fan work? Sometimes as 2F engines with stock carbs get warmer, the fuel in the carb will evaporate from the intake and even the float bowl. Thus, when you start it up warm it needs a little shot of fuel. That is what the accellerator pump is for. Take your air cleaner off, look into the throat of the carb and work the linkage. You should see a squirt of raw gas into the carb throat. I guess the first test would be to see if pumping the gas pedal a couple of times before you crank it helps. Of course, if the accellerator pump is bad, one would not expect it to help.
my 85 2F motor will do this and its always at the most embarassing time. when it does this i push the gas pedal to the floor holding it down until it starts. this always works for me. might be worth a try. good luck
mine did the same he other day trying to start on lpg.... dont know it started on petrol ok...
this has happened to me too a few times...flooring the pedal has always been the cure for me though this only happens when the motor's hot, and very rarely.
btw way, the owner's manual (at least for my 86 FJ60,) instructs you to floor the pedal while cranking a hot engine. i usually only have to press the gas maybe 1/4 to 1/3 of the way down.
is your carb fan working? another possibility is vapor lock due to an inop. carb fan...
