Starting noise on my '93:
lurker said:
Do you have the High idle problem?
I also had a sort of growl for a split second at around 1200 -1400 rpm at startup.
Once I did the 2 oil ring IAC mod, the startup idle never has been above 1000 rpm again so no growl, so mabe the root case isn't fixed bit at least it's masked. :confused:
Hmmmm........mine cold idles quite high. I just started it and it cold idles at 1700RPM. I let in run for a minuteand it's still at 1700RPM.
A/C off or on, same RPM
Temp outside about 55 degrees.
Is this bad?
Is this bad?
"Is this bad."
IMO yes.
I did the 2 oil ring mod to lower my startup RPM to 1000 and after 30 seconds to 650 rpm. The growl IMO is a lack of oil pressure or oil delivery at startup. I thought that if I lowered the RPM at startup at least it wouldn't do as much damage, but I could be totally off base.
Anyway please do a search for words such as "high idle" "iac" starting at the end of SEP, 2004. You will also find a link around ~oct 2 - 7 that explains what to do if some of the parts fall out. You can also search on my username around those dates.
There's a detailed link to www.4x4.com (< that's just part of the link) that has a instruction on how to do the mod. It's about a 3 hour deal if you have to pull the TB off, but still pretty easy.
OK all. Thanks for your responses. Here's what I've figured:
Noise NEVER occurs when cold starting when the AC button is off.
Noise OFTEN occurs right at start when the AC button is on.
Since I figured the above I tried this:
Cold start with AC off...no noise. Then, right after start push the AC button to on, and WA LA....SCREECH/GRIND noise is there for a split second then gone until the next morning.
Ideas? (Remember I recently had the AC idler bearing (whatever ya call it) replaced.
Sounds like the A/C clutch is slipping. If it has too much gap you maybe able to shim it, but probably better off just replacing it.
Kevin: Is the clutch different than the idler? The idler was loud when the engine was running (bearing noise from age) so it was replaced. This new starting sound came about a week after. J
The idler tensions the belt, it lives on the bracket. The clutch is the pulley on the compressor, engages the compressor.
It could also be the compressor starting to lock-up. It is almost surely the compressor/clutch combination. Also check the refrigerant charge, an over charged system puts a lot of strain on the compressor when it kicks in.
