- Joined
- Apr 21, 2005
- Threads
- 115
- Messages
- 25,799
A 2fe has a 2f shortblock with a 3fe head. You get higher compression and fuel injection. A 2f with sniper and timing control would be better if you bumped up the compression ratio of the 2f. Although the 3fe has nice manifolds too.
Because the early 2F which I have has domed pistons I was wondering if there was clearance issue with the 3F head? The 8/80+ 2F and 3F have flat pistons.
I do like the exhaust on the 3FE. I got the two first header pipes with a 02 sensors. Not sure if those are needed. Because I have the complete 3FE air cleaner to exhaust plus wiring and ECU would probably be a cheaper conversion.
