Starter repairs?
Hey compadres I need some help, my LX450 1997 is having starting problems. Tried to jump it with no luck. It is basically my wife's vehicle. She says it has been starting intermittently, sometimes with a slow turn over. When I tried to jump it today, just heard a clicking sound and something like a hissing sound as well from starter area. I talked to someone at parts store who said I should try cleaning solenoid contacts before I replace the starter.
I know some of you guys are real wrenches. How should I proceed so as to spend as little as possible. I'll be doing it myself. Thanks:confused:
Order the starter contacts and plunger from CDan or someone at American Toyota in NM, just mention MUD discount... Since it's your wifey's, can also checkout the PHH condition and battery wires/cables for potential problems.
Somewhat easy to replace if you follow the proper order of disassembly and reassembly, beats $380 or so for a Dealer remanufactured unit that has a core charge..
Thanks for the reply. Plan on cleaning up that battery cable; noticed a little corrosion around the terminal. Forgive me, but what do you mean by PHH? Thanks for your help. :)
Hello fokker and welcome to the 80 section here on IH8MUD.
To elaborate on the above recommendation... your problem has the classic "starter contacts" symptoms. The starter in the US 80-series is known to need service at ~100k mile intervals (depends more on start cycles than miles). R&R is covered well in the FAQ, on George's web site, and I think on the Slee off-road web site. Start with the FAQ here in the 80-Section and let us know if you have trouble finding the relevant thread.
The PHH is affectionately known as the "Pesky Heater Hose." That name has been around for many years and refers to the difficulty in replacing the hose. Well documented in the FAQ. The reason the poster mentioned the PHH is that it is a little easier to replace when the starter is removed. Kinda one of those "while you are in there" things.
The starter contacts come in a rebuild kit that is relatively inexpensive from your local Toyota dealer or from Cruiserdan if you can wait. 9 out of 10 times this will take care of your starter issues but sometimes a vehicle will need a new/reman starter. YMMV. Mine went out around 100k miles and I did a "trail fix" type of repair; removed the starter, cleaned up the plunger and contacts, and reinstalled. I got about 6 months before it failed again so I put in new contacts and plunger. That was ~70k miles back. It is good practice to make sure all connections to the battery are in good condition.
I will add that this is not a repair that you should put off, especially since your wife is the driver. We have had several reports of the starter hanging and creating other problems including very expensive damage to the electrical system. A few reports of fires. You need to stop driving the truck or repair it immediately using the above mentioned "trail fix".
Good luck and keep us posted.
-B-
The PHH is affectionately known as the "Peaky Heater Hose."
-B-
I know it's a simple typo, and normally I don't bust balls on typos, but it's "pesky."
I didn't want fokker sitting there scratching his head for too long trying to figure that one out. :D
Corrected. Thanks! :grinpimp:
-B-
Beowolf and Wob, thank you for your replies, and Beowolf thanks for such a detailed message. I will take care of that Pesky Heater Hose while the starter is off. I picked up a reman starter today, and will pick up a heater hose for it tomorrow if able, had to order the starter, but hope the hose can be found easily. Is it a special part (the hose), or easily replaced with a universal? Anyway I'll crawl under and look. Thanks again for the replies. Sorry it took a while to get back to you, but I have been on the road for a while. Thanks again. I will check those cable for corrosion. Gonna try and have it in the next couple of days.:)
The PHH can be replaced with a standard hose. Don't use Gates Red hose; it is too stiff. Their Green-Stripe is supposed to be pretty good and many have elected to use a silicone hose with constant tension clamps from NAPA. If you get the hose from your Toyota dealer it is a metric size and is cut to the exact length needed. I cannot recall the inch-size if you use std hose but there will be dozens of threads on the subject.
My recommendation is to buy 3' of the hose if you get Gates green stripe. Use 3" or so (whatever lth is needed) for the PHH and save the left-over as a long hose that could bypass the metal pipe in the event of a failure of the PHH in the boonies.
-B-
My wife also has a '97 LX450 with intermittent starting especially when it's warm. It always starts, but after a couple tries.
I reviewed many message threads on the same subject and opted to just replace the whole starter. I just ordered it from CDAN today.
BTW, when I married my wife she had a '84 Toyota longbed pickup. She remembered something similar happening to it as well. Starting became intermittent but never completely failed. We replaced it's starter and that fixed the problem. I'm sure there is no relation to these problems from very different Toyota trucks.
A little off topic, but I came across this on a Honda once...Similar Denso starter....The solenoid had frozen in the "On" position. It would continue cranking until the battery cable was removed.
I strongly advised the lady that owned the car that it could easily catch fire if she drove it like that, yet she kept insisting that she drive it all the way to her mechanic, WITH THE STARTER GOING.
I ended up towing her to the mechanic. Whew.
Back on topic...
Replacing the contacts on these starters can fix many sticking issues, i.e. intermittent starting or stuck solenoid.
hey focker, if you want my personal opinion in this manner (i have been through the same symptoms and circumstance) here it is:
if you want to remove and replace the starter twice, then order the plunger/brushes kit from cdan and replace those.
if you want to remove and replace the starter once, order a re-manufactured starter from cdan and call it a day.
Okay Amigos, many thanks for all the suggestions. Have just replaced with reman starter with lifetime warranty from local parts house (works great), hopefully it will not be a monthly item. 128$ plus core. I know I shoulda got Toyota part, but couldn't help myself for the money. Butttttttttttttttt! As far as the PHH, ---Holy CR_P--!!! Found I could, actually touch it, but I'm gon need a hole (in my head) different frame of mind before I jump that. It is still sound and not swollen no leaks. I know that these words will make me sad now soon, but the ole addage "don't fix it if it aint broke", kept poppin into my head? Anyway, I'm seriously trying to calculate the amount of beer it's goin need. I'll approach that one later:doh:
Thanks so much for all your help guys. You're great:cheers:
If you haven't returned the core starter yet, consider keeping it and rebuilding it so you have a spare when your 'lifetime warantee' starter takes a crap. It's an easy job, especially when you don't have to have it done in time to drive the car to work. :D I'd bet a local might buy it for the price of the core fee if you don't want to rebuild it yourself, or help you do the job. You anywhere in Az by chance?
-Spike
I've had great luck replacing plunger and contacts in 3 trucks. All have been rebuilt with Toyota parts and all work great. I think I did my 80 in 2003 or so and it's going great. You are basically replacing all the wear items, so just go for it. Buy a reman if you wish, but you don't need it. This starter is a great design-it basically never wears out, and the parts that wear are $20 a shot to fix. If you do it every 75k or so, you never have to worry about it.
