I had been dealing with an intermittent no-start problem last fall and I thought I had cured it. I replaced my contacts & plunger, no change. I found that my NSS was loose, so after setting it in position and tightening it down I thought I was good to go. Since then I've also pulled the plug off the NSS, cleaned it out and added some dielectric grease.
The problem has resurfaced again in the last few weeks. The symptoms are as follows:
A: Truck starts from cold perfectly in the morning, even with way below freezing temps. No weak cranks, no skipping, no problems.
B: Truck won't crank over at all when the engine is at/near operating temp. No starter crank, no solenoid clicking.
-When B happens I have two options: I can let the truck sit for 15-30 minutes to cool down, or I can use a jumper wire from battery positive to the connector on the solenoid. With either method the truck will start perfectly (like A).
I have gotten to know my multimeter much better since the last time I was diagnosing this problem and I have a few readings that I think might have some importance. When engine is cool and "startable", the voltage between the starter solenoid wire (black-red) and the solenoid terminal connector it plugs into is approximately 11.6v with the ignition at START. It is approximately 3.5v at ON.
After taking those readings I drove the truck around for 20 minutes to make sure I was at operating temperature and then it was back to the driveway. Turned it off and tried to start again, nothing. Took the same readings and had approx 10.6v at START and 3.4v at ON. Is this voltage drop acceptable?
I am thinking it's a problem somewhere within the starter. From my understanding there are two main parts in the starter: the starter motor that turns over the engine, and the solenoid that gets power to the starter motor with a trigger from the ignition switch. A lot of the threads I have seen here recommend replacing the solenoid as a cure for no starts; does that apply to my case? What is it that goes bad inside the solenoid? I am leaning towards the solenoid as the culprit but I would appreciate some input from folks here
