Starter motor connection area
Chino Hills, Ca
Good Morning.
My starter went on it on me yesterday and after I removed it from the engine compartment, I noticed the area just above where the starter is mounted having this opening.
im not sure if I accidentally opened it while removing the top starter nut or it’s suppose to be closed like the below picture
And could someone please help me and explain why this is there. Thank you in advance. I’m trying to learn as much as possible about my FJ40 and I’m not mechanically inclined. Thanks
That’s the timing indicator you use when timing your engine. It’s suppose to open for that purpose so you can use a timing light to see that the engine timing is correct. And when you’re done with that then you swing the “door” shut as you’ve done to help keep dirt out of the timing gear area.
If your timing marks aren't already painted, It would be a good time to do it while the starter is already off. The timing marks are easier to find and paint with the starter off.
