starter issues again...
No I havent, did remember seeing this though. I am assuming its directly off the tranny housing, assuming near ther starter? I dont recall this being a typical cure but worth checking before heading to the ignition. i will keep you posted...
thanks
Ok, I wont be able to get under the cruiser tonight, but after digging in to the FSM to review the neutral safety switch, I dont see any reference in the trouble shooting to "click" no start. To be clear the neutral start switch and neutral safety switch the same thing?
Haynes manual referes to check this switch if the cruiser starts in any gear other than neutral and park. Also operates the backup lights/reverse. BTW. The lights work when I shifted into reverse, if this means anything.
Has anyone actually fixed a no start single "click" by adjusting this switch???
It seems odd that the switch could be faulty or out of alignment. But I could be lookign at this wrong...
Again, this problem didnt begin with intermittent start ups where I have to crank the key 10-15 times to start. Out of the blue it didnt start and couldnt get it started.
thanks for the input..
Chris
I don't think the NSS would cause this to happen.
AFAIK, the NSS prevents current from flowing to the solenoid in any gear other than P or N in the first place. If it was out of adjustment, there wouldn't be a "click", or for that matter, any sort of noise from the starter.
My other concern regarding the ignition switch being the problem is I am getting a strong consistant 'click' and hum to the starter not intermittent. Also, if I didnt get any click when the key was turned this would mean I wasnet getting contact at the ignition switch?
In Roncrusier post, his cruiser was starting a few times then not and so on. So the ignition switch might be ok.
Try bypass the ignition and see what happens.
IH8MUD.com Forum - View Single Post - Intermittant starter
