Starter isn't quite working.
San Diego
So my starter for the last month has been acting up. I know it needs a rebuild and knew putting it off would lead me stranded somewhere. Well today was that day. Fortunately I was at my inlaws house and was safe. But now I need to rebuild my starter. I just want to double Check with the knowledge of the mud folk I'm going about this right.
So for the last month the starter would click. Then on second turn over it would turn on. Up until last week it took a couple cranks. Tonight there was no click at all.
So now it's time to rebuild.
Would this do the job? Being that I can have it at my door tomorrow? Or are there other recommendations for a rebuild kit...
Thank you!
Salty wrote:
"So now it's time to rebuild.
Would this do the job?"
Answer:
IF your contacts and plunger are the ONLY issues...then yes.
With most starters...that is the case, but my advice (unless it is an emergency situation) is to dis-assemble the entire starter and inspect it.
Mine needed new grease in the gear reduction housing, and the stator commutator needed cleaning up. All my bearings were still good, but yours might not be. The gasket for the starter solenoid cover is often brittle and it is best to replace it while you are doing the contacts and plunger.
Be certain to get the contacts level (on the same plane) with one another before tightening...or you will soon be right back in there.
You can also get a clicking starter from bad/loose/corroded battery terminals. Check your connections at the battery and make sure there's no corrosion on there. Also, an old battery can cause the click as well. What is your voltage? It should be 12.3-12.6 V. Any lower then you might need a new battery.
Checking that stuff first is much easier! I've had starter click issues over the years with different Toyota's and have had all those issues at least once causing the click.
When I rebuilt my starter I found some disturbing stuff inside, and ended up ordering bearings, soft parts, and regreasing it all.
If its never been rebuilt and it needs it, you might as well do the job correctly and do it one time.
If you need a starter to get you by, this cheapo from Amazon worked great for me. My 93 has the higher crank starter, so I wanted to rebuild it too, but daily drive my LC. So I bought this one from Amazon to hold me over and it has been on the truck over a year now. Louder on startup (kind of screeches a little) but cranks great...hard to beat for $77 shipped.
https://www.amazon.com/STARTER-TOYOTA-LANDCRUISER-228000-1560-28100-66040/dp/B0079SHII8?tag=ihco-20
I ended up buying a chepo repair. I'm gonna get to it on Sunday. 15$ shipped same day is a deal in my book... hopefully the contacts and the plunger is all I need but If not I suppose getting that wouldn't hurt lol. Thank you for sending that my way.
Yes, absolutely agree.
My bearings were fine, as were my brushes, but my commutator on the stator was worn and the grooves full of carbon and mica. Bendix was fine.
The grease in the gear reduction box was mostly hardened and almost none of it still on the gears. The majority of folks throw a set of contacts and a plunger in it (sometimes not even a plunger) and call it good, but I believe it is better to disassemble it and see exactly what it needs. That way you have no 'surprises' later on.
I'd recommend getting a set of JIS screwdriver bits (to include numbers 2 & 3). Makes disassembly a lot easier.
The DENSO 2800169 is only ~$87 + shipping and core return from Rockauto.com.
I saw that. I think I'm gonna tinker around with the rebuild and when it goes I'll be purchasing off of rock or amazon. For the meanwhile I don't start school for another two weeks so I got nothing better to do
Gheez now I'm getting all worked up and worried haha..
The grease gets old and hard, it picks up all kinds of nastiness.
Just open it up, clean it up real good, replace all the consumables, regrease and reassemble. Its not a bad job, several very good threads on here about it.
I wouldn't do it. Every place I've ever lived had at least one starter rebuild shop in it (look for it where the diesel repair shops are). For $40 you'll have a new, and pretty, starter and you won't have to wonder if it'll work.
As an update I ended up ordering the rebuild kit but I don't think that's my problem. I think it has to do with the OEM security. I was playing with the chip and realized how old it was. I placed in my backup switch and truck fired up with no "click" from the starter. So I'm now thinking it has nothing to do with the starter but perhaps the security system going to crap.
Any input on my theory.
I have a 93 if that helps.
