Starter, Battery, or Alternator Problem???
Yakima, WA
I've done my research on this site and my first tasks will be to check battery voltage and check & clean connections. But here are my symptons and I wanted to know what you guys think. The threads I've researched seem similar in some parts but not completely the same. So here goes:
Yesterday, I drove my 80 to and from work and it started up just fine a few times that whole day. Stopped at the store and when I get back in to start up the 80 it just clicks once and does not start. I do that several more times and no luck. I hear a faint whine which I presume is the starter. All lights are fine, headlights, interior LED, dashboard lights. I turn them on and off just to see if its the battery, but all seems fine there although I did not leave them on for a long time. When I turn the key, the headlights do dim a little, but not much else.
So eventually I get back to the vehicle and jump-start it. It cranks up real slowwwww, but it starts. Now the engine is behaving weak. RPM is much lower, around 400-500rpms and shaking quite a bit more than usual. On the short drive home, drives okay, but when I come to a stop, the rpms drop much lower than usual back down to 400-500rpms and shaking again. Does that every time I slow to a near stop and when just idling. I normally idle 900-1000rpms.
So is this just a weak battery (about 50k mile old yellow top Optima, not sure on age, haven't asked PO), starter contact replacement, or the alternator? I tried to start it again today and no luck, and lights are fine again.
Let me know what you guys think. Thanks ahead for your opinions.
My guesses;
starter solenoid
or
fuseble link
You can check the charge (but not condition) of the battery with a multi-meter. Also, the alternator.
Don't just throw parts at it.
Good luck, let us know.
Thank you for the quick advice guys.
It seems like its the battery. I swapped in my Tacoma's and it cranked right up, actually much faster than before. That Optima must have been on its dying legs.
I will purchase a new one and hope nothing else happens.
Do Optima's not last longer than standard batteries (i.e. Duralast, etc.)? As far as I could tell from the PO, he's had it for under 50k miles but not sure on how many years. Should be a few, and we've had some nasty hot summers the past few (SoCal). I can't justify spending that much if it does not last longer, plus I don't really have any power-hungry accessories yet. From research looks like Costco brand is pretty good.
I've heard mixed reviews about Optimas. Personally, I don't care for the "gel-cell" technology. My batteries have been doing fine even when jostled to the extreme (man, those speed bumps, whew), with the exception of the last battery...
