so that the teeth jammed somehow when the starter engaged, so it didn't really turn the engine but it was sinking a good bit of current. All the grounds were good, battery has good voltage and it has started up about 1/2 dozen times or more since Friday with no problems! So now that I got new spark plugs and new dizzy cap and rotor in there, with new wires coming soon, the Cruiser runs great! Thanks guys, sorry I freaked out, but I just am not used to hot smoking wires under my hood
. So me and a buddy went off in the hills for the rest of the morning and about 4 hours later come back and try again. Without touching the keyswitch we reconnect the hot lead on the battery. The starter doesn't turn. So I try starting the truck and it starts right up! So it appears that the new starter solved the clicking problem I had originally, but now it seems that maybe the keyswitch needs to be looked at? We were thinking that something between START and ON isn't functioning properly and cutting power to the starter. Does this sound right? How hard/expensive is it to replace the keyswitch? I'm not out of the woods yet with this one... subzali said:I'll stop at the auto parts store and pick up some ground wire first, 'cause I did notice that at least the strap from the starter to the frame looks like it should be replaced...
I am going to go with a bad ground strap from the starter to the frame. This is identical to what happened to me. It is intermittant, heat related and burning wires are the tell all for me.IDave said:We aren't really saying different things. I agree with replacing the wires and the contacts, but I'll bet the fault is in the switch, and that is why it is intermittant. It is worn, so the positions are fuzzy.
In other words, the contacts within the switch ARE the intermittant ground fault.
