When you are in 4 low do you ever shift out of 1st gear? Mine seems to only stays in first up to about red line, I dare not push it any further.
[edit] *While in normal 4 hi* when traveling around the mountains a couple of weeks ago I coundn't lock my transmission and have it stay into any particular gear (other than high), well it would stay there longer than normal but would jump into a higher gear. Same story when trying to engine break using the shifter. The handle stays in place, of course.
I see that Extreme transmissions makes a Manual Torque Converter Lock-up Kit, so I'm not so sure that I even have a problem?
FWIW, I've changed my transmision fuild about 5 times in the last 10,000 miles and the color is now fine, but cluch plates do the 500 extra rpm duing upshifts, which is sort of, kind of, hopefully normal.
Any suggestions other than a complete tranny rebuild or is this basically normal?
Just kidding.
