Stalling Issue
Plano, TX
Went wheeling the other day and the truck (3fe) stalled 3x when in a steep nose down situation. The first 2x it started back up, but the 3rd took a few seconds. When it stalled it just cut out, no sputter, no noise. The 2 theories on the trail were a bad fuel pick up / screen or a bad electrical connection. The first will be easy to fix, the second is what I'm asking about. Has anyone dealt with a similar problem? Anyone have a path of attack you'd follow to trace this? I don't see any obvious hanging wires. Also could a battery "going bad" produce this effect? In any other position the truck was fine, steep nose up or off camber in either direction. Oh...almost forgot, a couple of times the truck would low idle (450 +/-) when placed in park, most of the time it would be fine. Finally the truck hasn't done any of this on the road.
Thanks.
Jon,
Did your's sputter or just turn off?
