Ive searched the forum but haven't seen this exact problem. The Golden Goose starts great, runs great for a mile or so till it warms up slightly then wants to stall at lights. She'll also stall if I'm coasting and the rpms drop down. GG runs high rpms(900-1100) until she warms up. If she does start again, it takes flooring the accelator and continual cranking. Most of the time, I put her in park, turn the key, and get nothing! No engine turnover, no hope, just silence(this part just started yesterday). A few minutes later, she'll crank and I have to keep rpms above 1200 to keep her running. There are no cracks in the air intake hose. This problem began after I moved from Louisiana to Denver. I began using premium gas because of some very disappointing performance in the mountains. Ive tried the brake cleaner, intake butterfly valve trick and it seemed to work great for a week. I adjusted the throttle cable to increase idle speed, no change in the problem. I pulled the sensor on the drivers side of the intake manifold and cleaned all the crud off. My next step is to check all wires for a short(if I can get her home). Any suggestions?
