Stabbing the front axle shaft?
Flagstaff, AZ
I have a '72 FJ55 that I am doing a disc brake conversion on. I have birfields from a '82 FJ60 and have ground down the bottom of the ball on the axle. I can put the birfield in that is not attached to the axle shaft (sorry if I have the wrong names for some of this stuff) into the ball OK, but when I try to put the birfield in that is attached to the axle then I feel like I am bottoming out on something. I can get it right to where the birfield is starting to go into the ball and then it stops. I hear a sound coming from the ball and also in the front differential.
Any tricks?
BTW, I have not removed the opposite side and using the same shaft that came out w/ my old birfield on it.
Thanks,
Brian
The trick is that you have to "lift" the inside end of the shaft so that it can fit into the side gear. Pressing down on the outer end and using the seal as a pivot point tends to work. Then you have to turn it to get the splines engaged.
Or you could just turn the cruiser over on its side and drop it straight in. :D
X2 on what pinhead said
Turn the pinion or driveshaft just a tiny bit at a time. Then try and try and try and then it will go clunk and just slide right in. I just did this two days ago and was just about at my wits end, before I heard the clunk. Dont give up it will fit, it just might take an hour or so. Albee
Crap - I gave up about 45 minutes too early. I'll try again tonight.
Given that you say "it will go clunk and slide right in" that would imply it didn't need any encouragement, once the splines are lined up, from a rubber hammer?
Thanks,
Brian
Thanks,
Brian
Yes, it will slide right in once you get it lined up. You will be amazed.
The major issue is that it will never slide in if the inside end of the axle shaft is dragging on the bottom of the axle housing tube. Rest the axle shaft on the bench with a fulcrum at the seal surface and practice pushing down on the short end so you get an idea of how much grunt it takes to lift the long end up. It takes a lot more grunt for the long side shaft.
So when the birfield gets to the edge of the ball, then the inside part of the shaft still needs to lift up more - in addition to the lifting up to get it to that point?
Chances are then I was dragging it on the bottom of the axle housing tube. Is that what you'd guess?
BTW - I am working on the passenger side right now.
