Just got a new 80 series with the 1fz-fe engine and it is sputtering and cutting out. Said to have 80K on the engine and tranny and 207 on the rest if that helps out at all.
The problem -
It has only done this twice but while driving 50-70 it will just start to lose power and probably drop 1k revs then pick up then drop again and so on for about 10 seconds then it will go away and be fine.
Under acceleration it kind of sputters til about 2K then takes off and runs great. Then while I am stopped it will idle at 600 for a few seconds then drop and jump between 400 and 600. Happens really bad when it is cold. Takes a while to build up speed.
I am thinking the fuel pump is just not giving enough juice and I heard they are two stages because it runs great and high rpms but the lower revs it sputters. Also think this because with the idle coming from higher revs there is pressure built up so it idles fine for a while but after the pressure drops the fuel pump is struggling and it decreases and stutters. Checked the oil no white crud and antifreeze is the right color.
One thing that scares me is that when I take off the oil cap its like it is under pressure and it drops and runs like crap until put back on.
I could be wrong but anything will help this is my DD and kind of want to get it running a lot better.
The problem -
