Sst 09032–00100
Germantown, MD
Background: Couple months ago I got hung up on a huge rock on a wheeling trip and dented my #2 oil pan near the oil drain bolt. That had probably shaken up the oil pan and now it looks like the pan is leaking from the exhaust side through the FIPG seal. The leak seems pretty slow, it only happens when the engine is hot and the substance seems more of the FIPG material mixed with oil (black gooey stuff).
Anyway, so now I am thinking of re-sealing both #1 and #2 pan. I came arcoss this SST when studying the FSM. Has any one ever used this SST, it's an FIPG seal cutter.
2nd question is: Do I really have to raise the engine to take out #1 oil pan, I did not see any mention of the raising the engine for this in the FSM. I have looking at the oil pan arch seal thread that Alia started a while back.
3rd question: To raise the engine 3" to 6" do I have to disconnect the exhaust pipe, tranny shifter and etc?
Thanks for the info
:cheers:
3rd question: To raise the engine 3" to 6" do I have to disconnect the exhaust pipe, tranny shifter and ete
You only need the engine up about 1". I didn't pull anything but the two bots on each motor mount. Just raise the motor till the fan touches the shroud. The SST is for removing #2 pan and with the engine in the bay there is no room to get in there and use it. Just tapping the sides of the #2 pan with a rubber hammer does the trick. On the #1 pain, I didn't use a screw driver in the corners like the FSM calls for. I took my brass drift and smacked down with a 5lb hammer on the corners from the top--it didn't take much pressure to break free.
Just be ready to hate yourself for starting this job when your elbow deep into it.
don't forget the o-ring for the oil pump pickup! and pick up the two new o-rings for the dip stick. The oil level sensor doesn't need to come out but if you do pull it out get a new seal for it.
