SRS Airbag codes?
St. Louis, MO
I have the airbag light on due to disconnecting the guage cluster for too long. I found some old threads on how to output the codes and how to reset the system. After following the old threads, I determined that I have a code 22, but before I reset the system I'd like to make sure that relates to the power disconnect and not an actual problem. I'm hoping someone can point me to the SRS codes. Thanks!
Below is the older thread that includes how to output the codes by shorting the appropriate Diagnostic terminals in the engine bay and then reading the flashes of the SRS Airbag dash light.
Then, later in the thread (post #5), is the procedure for resetting the SRS Airbag fault light by grounding yet another set of terminals in the Diagnostic control. FWIW, I ended up using 12 gauge solid wire and grounding to the battery negative terminal. It seems to be key that you check for continuity between the two wires while they are inserted in the appropriate terminals (before grounding) and then make sure you ground each one long enough (less than the one second time instructed will not work) and then hold the final ground for at least 5 seconds.
https://forum.ih8mud.com/80-series-tech/157278-airbag-reset-proceedure.html
Again, if anyone knows the meaning of code 22 I'd love to have it. I reset the light b/c I'm 99% certain it only came on b/c the power supply was interrupted too long. Still, I'd feel better if I could confirm that code 22 was nothing to worry about.
Sorry to double post, but I added a bunch more info via 'edit' and wanted to make sure it was seen.
