"Squishy" 88 4Runner build
NorCal
Hey guys here is my 88 4Runner that me & my Dad (CMY4XGO) built. Lemme know what ya think!
Here's what's it's got.
•Installed 5.29 R&P and Detroit Tru Trac into rear diff.
Also changed out outer rear axle seals, and pinion seal.
changed spark plugs, ignition wires, cap, rotor. Checked compression (all cylinders at 191)
•Removed TB and intake manifold for cleaning. Installed 2nd Gen rear seats, installed Grant steering wheel, replaced HVAC bezel.
•Serviced rear roll up window, installed rear cargo mat, degrease engine as necessary.
•Changed out cluster bulbs to amber ones, sent gauge cluster in for white face overlay, replaced fan speed resistor, installed billet pedals, billet shift knobs.
•Performed key switch mod, cargo lamp mod.
• Installed white face gauge overlay, blacked out center bezel.
•Installed 2" ball joint lift up front, ZUK mod rear coils in rear, new Pro Comp 9000's all four corners, new OME steering stabilizer.
•New PCV, replaced battery, TB cooling hoses, various gaskets in intake area.
•Installed Hobbs retractable light in engine bay, wired in various LED lamps for interior lighting.
•Installed remote fuse block behind glovebox, ran power feeds to rear of vehicle for future use.
•Installed CB radio, 12v sockets, relocated center console switches into dash areas.
•Installed Scion radio (it was a plug n' play deal)
•Jumped out rear window relay so that rear window can be operated without a key in the ignition.
Installed Marlin rear bumper,(modified to suit)
•TRD stickers, paint & riveted front grille, changed over to clear front turn & marker lenses.
• replaced reverse lamps with 8 watt Cree bulbs.
•Installed diamond plate to factory skid plate with holes punched out to increase airflow to engine.
•Converted from auto to factory Aisin manual hubs.
• Installed Viair OBA system.
• Installed 5.29 R&P and Detroit Tru Trac into rear diff.
•changed out outer rear axle seals, and pinion
• Installed new Aisin clutch master cylinder & slave cylinder.
•installed new timing chain from DOA
• 1.5" wheel spacers installed
• BFG all terrain KO mounted on stock 15x7 wheels 143k miles in truck
• Trail Gear Twin Sticks installed
• Installed Turbo Clutch/ flywheel
• Front calipers painted red
•5.29 front diff gears installed
• OEM thermostat installed
• Engine components/radiator shroud/ steering stabilizer all painted.
• Front & rear differential breathers installed
• Side 4runner B-pillar door sills painted
• CB radio antenna & wire mounted & routed into CB base in cab
• Fuel filter relocation done
•Toytec 2" BJ lift
•Rear Zuk mod
•Pro Comp shocks
•Replace turbo clutch
•Replace turbo flywheel
•Replace pilot bearing & boot
•Deep cycle battery
•Black out grille
•Front clear corner lenses
•Front clear bumper lenses
•Rear clear taillight lenses
•Factory Inclinometer
•Single gauge piller pod
•Install vacuum gauge
•Install CB radio
•Weld in CB antenna mount
•Change armrest into cup holder
•Install white gauge overlay
•Black out dash panels
•TrailGear shift knobs
•Grant steering wheel
•Amber dash lighting
•Interior LED lighting
•Recaro front seats
•Factory rear seats
•Rear cargo mat
•Rubber floor mats
•Billet foot pedals
•5.29 locked rear axle
•5.29 IFS front third
•2.5" Flow Master system
•home built sliders
• TPI Bimini top
•Upgrade speakers
•Trail Gear twin sticks
• vinyl floor mats
•Marlin Hi output H4 head lamps
& here is what you have all been waiting for pictures!
Wow, it's surprising how clean that thing is. Nice work!
Would like details on these...
Where are you carrying your spare, with the air tank in the way like that?
Good looking rig.
First off thank you, it's been a fun project.
That was my bad it's actually a 10 watt, here's the link for more info. Basically just a much brighter light output then a standard incandescent bulb.
http://www.autolumination.com/1156_1157.htm
The retractable light in the engine bay is an ending light out of a 89 Chevy dually 1ton. It's made by Hobbs . It's a 1157 bulb that has a retractable magnetic base that unwinds & can stick anywhere on the hood then winds back into a housing I have mounted on the underside of the hood. I'll post a picture up as soon as I can.
I'm really liking those Recaros. I love my SR5 seats, but they are over 30 years old now (came out of my '84) and getting tired, so if I ever need to replace them I would consider those.
Yeah if you can find them I recommend em! They are super comfortable & & sit a little lower then the stock ones
Thanks. I'm torn on getting my stockers redone or putting new ones in.
Very nice truck;)
Thank you sir!
If your half way handy they aren't that hard to modify. I just used a vise & a welder. Few tries & it came out just the way I wanted
