Springs & Shocks
Tire pressure? I don't this so. The truck sits 2" low in the back and it runs right through the shocks.
get bigger shocks...... :D
OK..I am going to try another round of springs and bigger badder shocks. If that does not work, I will look for some springs out of Australia. Slee heavies will not work...I checked the specs and I am way over what they are rated for. I will sit low in the back with those as well.
FWIW, shocks are not going to give you load carrying capacity. Springs will. I urge you to try and contact Desertdude. As much as you think your truck is loaded more than everyone elses, it is not.
Far Nay, I will post pics of shocks and details when I have more to share. Little pre-mature at this point.
Doesn't Rick have a set of our 4" spring that you can try. I do not believe he has heavies for the rear, but at some point he had some.
Yes, I am trying to be sensitive to those that worked on this for a variety of reasons .... but they are FOR Springs that were custom made to order.
See my specs on the OP. The data is all there. It really does not matter what I am running as they are not working. Also, I can do the math and see that Slee Heavies will not work either.
Yes, there are trucks out there with similar weight loads by mine bit they are using compromised solutions in my opinion. I do not see anything in the US that will handle this except the short lift ARB Heavies that are rated for 1,300lbs each. They may work, bit do not provide enough lift.
Also, my tolerance may be far less than others when it comes to compromise. Sitting 2" low in the rear and almost 1" low in front ... and driving a truck that will wallow and porpoise down the road to the point of being dangerous to drive ... just is not going to cut it for me. The damn thing "drives like a Lincoln with blown struts" according to someone else who drove the truck.
I agree that progressive springs are not the answer. I am trying one more revisions with FOR to see what he can do. If I can talk him out of Progressive springs and get spring rate that is targeted towards controlling the truck ... instead of attempting to have it ride like a Cadillac sedan ... I might get a set of springs that actually work.
Just out of curiosity, modified how? Higher base spring rate as a custom build?
This is a pretty cryptic thread. You aren't really giving us much information on what you have on the rig now, but are claiming that real world tested solutions for heavy weight 80's will not work for yours.
The solution for a very heavy vehicle is not a progressive rate spring. It is a high quality, high base spring rate. If you get upwards of 300 lb/in you are 50% spring rate higher than stock, give or take. The weight of your 80 at max is not more than 50% increase over stock, and there are springs out there at this lb/in rate for the 80.
So if you pair these springs with good shocks at the right valving, you should have the full expectation that this is going to perform appropriately. Your setup is not really out of the box to others here. Plenty of people have fridges, drawers full of tools and ****, heavy ass bumpers on both ends, RTT's, and on and on.
Custom suspensions are trial and error, there is no way around it. And there are limits to good performance on a coil suspension, which is why heavy duty trucks still use leaf springs.
Frankly, a simple rear leaf spring conversion would probably perform excellently for you if you really don't want to try a high rate coil spring with a very high quality and high valved remote reservoir shock. There are points where leaf springs will simply outperform the best set up coil suspension because of the bias to weight.
Are you at coil spring limits? Hard to tell, because we don't really know what you are doing other than testing a custom coil that hasn't provided a level ride or performance. I once bought custom leafs/coils for my XJ, both top of the line with my rig weighed on a truck scale, to get a 6" lift, and I ended up with 2" in the rear and 9" up front. That was a fun drive home 120 miles from Ft. Collins.
My solution was to go with a quality off the shelf spring that was well tested to provide a good spring rate and ride height. I paired these with some high quality Bilstein shocks and ended up with exactly what I had wanted to achieve with my custom suspension. Lesson learned, although that never damped my interest in testing new designs.
I'm the first on this forum to say I think the 80 series market lacks innovative suspension designs, but that is from a "keep it light, dual purpose crawler" perspective. If you are all expedition weight, buy the expedition suspension. It doesn't get any easier than that, and this stuff has been on the market for years.
Hi Christo,
500lb to 700lb load carrying capacity will not work for me. That is what your springs from Australia are rated. I am well over 2,600lbs total over stock ad a daily driver and closer to 3,600 fully loaded. I need something heavier with 3.5" of lift all the way around...minimal stinkbug look if possible.
I idealy I would like something that sits 1/2" to 3/4" high in the rear at 2,600lbs and no more than 3/4" to 1" low with 1,000 lbs of gear in the back.
Is that even possible?
Yes, I need those too. I questioned using standard FOR Shocks...I knew they would not come even close to cutting it. The damping control is non existent with stock FOR Shocks at this weight.
Get the short lift ARB heavies. Put in spring spacers (either space down the spring mount or coil spacers). Put in a 2" body lift.
Weight and lift problem solved. ;)
But them I would have more limited travel ... correct? I am not sure it is that simple. If it were I would consider it...but I would think a system designed to run at a 3.5" lift height would perform better overall.
Why would you have more limited travel?
Lift is lift. While up here in the States if you utter "body lift" Land Cruiser owners immediately think "Jeeper!", in other parts of the world a body lift is just about standard.
In Australia, for example, you have to have your rig certified every year or so. Lifts over a couple inches are hard to pass (because they change the driving characteristics), so body lifts are common. While I was browsing the Aussie forums when someone asked how to get X inches, the respone was usually something like "2 inch spring lift, 2 inch body lift."
There are some very nice bonuses to a body lift.
One, it's cheap (under $100 if you do it yourself, $150 if you buy it predone).
Two, you only lift the body, not the engine, frame, etc. So your COG stays much lower as you are lifting much less weight.
Finally, the lift you gain stays, no matter how much weight you load up with.
Spring spacers have much the same arguments for them, except obviously the weight one doesn't apply as you are lifting the engine and frame along with the body.
The only real down side to these is that a longer spring will stay captive better (especially the FOR's). This is easily solved by retaining the spring on one or both ends.
Because of the amount of weigt you carry, you will have issues with losing lift due to spring compression. One option is to go with alternate methods that will give you lift, but in ways that you can't lose the lift you gain.
I'm running both a body lift and a coil spacer, btw, and am very happy with both.
Who is Taco?
*points to his avatar* :grinpimp:
Yes, articulation was part of my concern. It just seems that I would get more spring travel in both directions with a full length spring....the way my mind envisions that, this is what I see. I could be wrong, but if the spring is let's say 12" total to get 4" of lift over stock verses 8" with a spacer to get the same lift, I would imagine the longer spring has more travel .... in both directions.
Also, I am still a newbie of sorts, so I am not clear what spacers do. You say you lift the body but not the engine, frame, etc. So doesn't that also give you less ground clearance in these areas?
forgive me if I missed it, but what is your actual purpose for the vehicle. What type of off roading will you be doing with that much weight in your ride? Desert cruising, rock crawling, dunes??? Seems like a recipe for breakage of parts to me. Is this a work vehicle or pure pleasure? I agree with cattledog, why not just get a nice trailer and call it good?
Yes, and that's exactly what I meant by that a longer spring will stay captive. A shorter spring is more likely to fall out. You can easily get around that by retaining one or both ends of the spring.
I assume you're talking about the body lift here, not the spring spacers. They are two different things.
The body lift allows you to clear larger tires and gives you room to articulate. It does not effect ground clearence much, except that your body panels are that much further away from the ground. So your frame, engine, drive train, etc stay the same distance, but your body moves up.
Since articulation is often limited by the body, this lets you have more up travel and/or bigger tires. Obviously if you aren't rubbing on the body, and are only rubbing on the frame, then a body lift won't help you much.
Most people tend to rub on the body though, unless you've dropped your bump stops way down.
Clear as mud?
