Springs & Shocks
New York & California
Website
www.rbfilms.com
I have not posted final details of my build yet because it is still not finished and it is not quite right yet either. I am still waiting on several items that need to be completed and a few things to be corrected. I expect it will be completed soon.
The most annoying issue at the moment would be my Springs & Shocks. I am having serious issues with my Suspension. My truck wallows and dives big time with the custom suspension I have now. I need something that will handle the weight of my vehicle and I have spent a LOT of money so far on a solution that does not work ... albeit, I was assured it would work. That is a long story I am not getting in to right now.
At the weight I am running, Slee Heavies won't do it. I need something heavier that will give me a 3.5" lift. I am not sure anything is made for this so I am posting here for help and ideas. If there are any suspension Gurus out there, I am in great need of your assistance.
Here are the specs on my truck for those engineering types out there that may be able to make some recommendations.
Truck Ride Height:
3.5"
Truck
Weight
Actual
Weigh
as
per
a
Truck
Stop
CAT
Scale
Front
 Axle:
3,300
lbs
Rear
 Axle:
 4,300
lbs
Total
 Weight:
7,600
lbs
 (40%
of
the
Time)
NOTE:
Vehicle
Weighed
 with
 a
 Driver,
Passenger,
Segway,
Refrigerator,
Average
 amount
 of
Gear,
and
 both
 Fuel
Tanks
full of
Fuel.
 This is how I drive
the
truck
pretty
much
20%
 of
the
time
Front
 Axle:
3,300
lbs
Rear
Axle:
4,100
lbs
Total
 Weight:
7,400
lbs
 (60%
of
the
Time)
NOTE:
Vehicle
Weighed
 with
 a
 Driver,
Passenger,
Refrigerator,
Average
 amount
 of
Gear,
and
 both
 Fuel
Tanks
full of
Fuel.
 This is how I drive
the
truck
pretty
much
60%
 of
the
time
Payload
Capacity
The
 Stock
 Weights
and
 Payload
 Capacity
of
the
truck
before
after
the
build
are
 as
 follows:
OEM
Payload
 Capacity
of
Stock
Vehicle
OEM
Specification:
1,433
lbs
Base
Vehicle
Weight
5,000
lbs
Gross
Vehicle
Weight =
6,433
lbs
Build
Payload
 Capacity
Required
 for
 Passengers
 Luggage:
Build Specification: 1,430
lbs
Minimum
Base
Vehicle
Weight
7,600
lbs
Gross
Vehicle
Weight
 = 9,030
lbs
NOTE:
I want the springs to od teh work for my daily driver and loads up to 800lbs. Beyond that, I expect I may need to use an air bag helper system to carry this payload to maintain a decent ride height. Are the air bag systems reliable and do they work as advertised?
Equipment
added
 to
 Stock
 Vehicle
Estimated
Weight
(Daily
Driver)
 2,400
lbs
 of
Weight
added
 to
 Stock
Vehicle
in
Total
With
People
 and without
any
 gear
in
truck
. Used this way 40% of the time.
Estimated
Weight
(Daily
Driver)
 2,600
lbs
of
Weight
added
to
Stock
Vehicle
in
Total
With
 People
and gear I have on board as a
Daily Driver
. Used this way 60% of the time.
Any assistance would be greatly appreciated. I am at a loss for a solution.
I am sure you won't like this suggestion, but you are 2600# over the max gross weight of the truck. Loose the weight. Consider a M416 trailer for the "extra" equipment you want to drag on an off road trip.
If no trailer then remove the equipment that is not needed or used. I.e bumpers, extra gas tank, segway, refrigerator, kitchen sink and or other equipment. Or look for a different build platform i.e. non landcruiser for your build.
In the truck's current state, I would not use airbags the truck is just too fat and you will have no articulation in the rear.
Good luck.
Btw, what tires are you running? I would double check the load rating, and adjust the pressure to the correct range if possible.
Toyo AT 35 inch tires with 488 gears and a Supercharger. I have no complaints about the engine actually...it does very well with this weight ... so do my upgraded brakes.
What should the tire pressure be?
You are correct. That suggestion will not work for me.
Everything is permanently mounted. About the only thing I could take out would be the recovery gear and tools I carry with me. That won't be more than 200lbs and it defeats the purpose of why I built the truck and what I built if for in the first place.
Good luck.
I am not trying be an ass, but I want just want to point out your truck's weight in perspective to another SUV. The 2005 Ford Exursion 4x4 diesel the largest mass producted SUV ever has a GVW of 9200 lbs. From the factory it came with a 44 gal fuel tank, and seating for 9 with luggage. From the sounds of your build that may have been a better platform for the build. IMO, Your truck is just way too heavy.
I am not going to do your homework, you need to look up the tire specs and calculate or call the manufacture for the proper pressure. Tire rack has a good information for calculating the correct inflation pressue. Much of your issue could stem from the tires. What load range are the tires?
Just to clarify, you are not running our springs, correct? Have you tried them? For the record, we had our 6" heavy springs on our 100 series with the SAS that topped the scales at 7400lbs and we drove it on the road with no swaybars and we did not have the issues you are addressing.
FWIW, here is a thread on a guy that built a truck like yours and ran the 4" springs with great sucsses all the way to AK and back. You might want to PM him (not sure he is on MUD) for his opinion.
http://expeditionportal.com/forum/showthread.php?t=148
FWIW, we also have access to direct bolt in remote reservoir shocks that can be valved to suit.
Slee heavy 4" springs should be exactly what you are looking for, I think you are over thinking this.
What I would do, however, is get a set of Bilstein short body 7100 shocks in the highest valving range (you'll need eye adapters) rather than using OME shocks.
At your weight point, you really need a very high end shock, and for a 3.5" lift with eye adapters the short body/remote reservoir is going to give you the correct shock travel.
You should post up your actual current springs and shocks if you want to get a good comparison in this thread.
You could also compare the Slee heavies to the the OME expedition springs or whatever they call them, but personally my money is that the Slee spring is much higher quality.
No need to reinvent the wheel, plenty of people run around with expedition weight 80's, and Slee's kits are directly designed for this.
:popcorn:
I think he is runing FOR Gen 2.
If you are, i may buy them from you when you buy your new Slee heavies. Pm me.
If so, he should keep the springs and go to far more valving on the shocks before doing anything else. FOR shocks are very lightly valved and would be a non-ideal choice for that much weight if he is running them.
Of course, at a certain weight progressive anything is somewhat out the window anyway...
Tire pressure? I don't this so. The truck sits 2" low in the back and it runs right through the shocks. There is very poor spring or damping control on this vehicle.
A Ford a better platform? Uh ... sorry ... that would be a no. These truck can easily handle what I have done to mine. Power is not an issue at all with my modified heads, blueprinted valves, and supercharger. It runs strong.
The springs and shocks I installed are simply not cutting it. That is a fact. I can assure you, it has nothing to do with tire pressure ... but thank you for the thought. I will check the specs to see if should be running higher pressures. That won't fix my problem but it may help on road handling a bit.
No, I am not running your Springs Christo. I am using a different product. I looked at the specs on your heavies and while they are good for most people ... they won't cut it for my truck.
I will check out the link...thanks..:)
Desertdude -1997 80 series build up - Expedition Portal Forum
It is a custom version of an FOR...supposedly modified for the weight....but it ain't workin'
Just out of curiosity, modified how? Higher base spring rate as a custom build?
This is a pretty cryptic thread. You aren't really giving us much information on what you have on the rig now, but are claiming that real world tested solutions for heavy weight 80's will not work for yours.
The solution for a very heavy vehicle is not a progressive rate spring. It is a high quality, high base spring rate. If you get upwards of 300 lb/in you are 50% spring rate higher than stock, give or take. The weight of your 80 at max is not more than 50% increase over stock, and there are springs out there at this lb/in rate for the 80.
So if you pair these springs with good shocks at the right valving, you should have the full expectation that this is going to perform appropriately. Your setup is not really out of the box to others here. Plenty of people have fridges, drawers full of tools and crap, heavy ass bumpers on both ends, RTT's, and on and on.
Custom suspensions are trial and error, there is no way around it. And there are limits to good performance on a coil suspension, which is why heavy duty trucks still use leaf springs.
Frankly, a simple rear leaf spring conversion would probably perform excellently for you if you really don't want to try a high rate coil spring with a very high quality and high valved remote reservoir shock. There are points where leaf springs will simply outperform the best set up coil suspension because of the bias to weight.
Are you at coil spring limits? Hard to tell, because we don't really know what you are doing other than testing a custom coil that hasn't provided a level ride or performance. I once bought custom leafs/coils for my XJ, both top of the line with my rig weighed on a truck scale, to get a 6" lift, and I ended up with 2" in the rear and 9" up front. That was a fun drive home 120 miles from Ft. Collins.
My solution was to go with a quality off the shelf spring that was well tested to provide a good spring rate and ride height. I paired these with some high quality Bilstein shocks and ended up with exactly what I had wanted to achieve with my custom suspension. Lesson learned, although that never damped my interest in testing new designs.
I'm the first on this forum to say I think the 80 series market lacks innovative suspension designs, but that is from a "keep it light, dual purpose crawler" perspective. If you are all expedition weight, buy the expedition suspension. It doesn't get any easier than that, and this stuff has been on the market for years.
Did you give your spring manufacture the actual axle wgt when he made your springs?
If you give him an estimated wgt, then I would call him with the true axle wgt.
I'm sure that he can make you the correct springs.
If you get a custom spring right on the second try you got lucky. First try you'd better know springs and be able to take your truck to the spring manufacturer.
To nail a custom spring I'd expect to pay a premium for a minimum of 3 versions.
I doubt I'd use the FOR spring as a base for this application unless I was looking to enable extra droop with a very high base spring rate, because the progressive feature would be non-existent. This amount of static weight/compression could also provide "beyond specs" stress in the live to dead wind transition. This may be why the rear is sitting 2" low (the coils are failing).
Instead I'd be looking for extremely low variance in spring rate throughout the load range and spring travel. In other words, a very high quality high spring rate design. Again, paired with a very good shock, remote reservoir in this case to prevent fade in controlling this much weight, particularly at speed off pavement.
Again, without understanding the design goals in terms of usage, it's hard to make a recommendation. A crawler at high weight needs a very different application than a high speed overlander. How you design spring travel, suspension range at compression and extension, and shock valving is totally different in these applications, especially at GVW limits.
This is not the 2nd try but the info in this thread is helping a great deal.
