springover questions
burbank ca
hey everyone i have a 72 cruiser rear is currently sprung over front is not, front has 4 inch skyjacker springs rear is stock forty springs
im toying with the idea of springing over the front and was wondering if any of you would give your thoughts and opinions this is my daily driver so it needs to be sturdy at freeway speeds. what springs to use? should i do a shackle reversal?
any thoughts and opions would be greatly aprecated
thanks, matt
stock springs, all 7 leaves, shackle reversal is recommended, cut-turn the housing, etc. Pretty standard SOA stuff really. I'd run a gas charged shock, not one of those $30 cheapies.
coolcruiserfj40 said:
any opinions on using 60 springs? (iknow id have to move my mounts around)
Give me a little time Matt and I will let check mine out it will be sprung over front and rear with 60 springs all around. Take for test run and you can see if you like it.
:flipoff2: :flipoff2:
Phil
Phil
i call driving on the maiden voyage :flipoff2:
im gunna be over there tommorow so if i get simon to push me around the shop while i sit in the drives seat doesnt that mean i got to take it on its maiden voyage? :flipoff2:
I 'll give that one but I'm taking the first under its own power that will be the maiden voyage
tlc73fj40 by any chance are you using the 60 series axles aswell ?? get some pics up
I am planning on using 60 axles on my 40 with the rear springs from the 60 and the stock 40 springs up front
the 40 axles seem too skinny with a spring over and 35s on 8 15x8 rims
I running 40 axles front and rear and 60 springs front and rear it will be SOA with 35 on 15 x10
Here is a link to my build on pirates iff you want a pic of anything special let me know and I will get for you
http://www.pirate4x4.com/forum/showthread.php?t=336050
tlc73fj40
Dude your build looks f-ing sweet I like the motor mount crossmember idea! and thos universal mounting plates :-) man that is gonna be a sweet 40!
