Spring Pack Thickness???
Tex..as...Ohhhh...Texas!!!
Ok...
I currently have some U-bolts that need serious trimming (long ones from CCOT).
The spring packs on my 40 are about 1 1/2 inch thick were the axle sits, and the PO added some aftermarket "extended" shackles to the rear hangers.
In the future I plan on replacing both the shackles and the springs, but I need to trim these u-bolts now! And I want to avoid shooting myself in the foot by cutting down these u-bolts too much.
Can any of y'all out there give me some measurements on spring pack thickness?
What are the thickest springs on the market currently?
How thick are the OME springs?
What about HFS?
Thanks,
if you replace your springs you should replace the ublots with them as the ones you have now will be streched from torquing. I think thes what you supposed to do
after all you dont want those axles falling off
Chris,
Thanks for the info...With any luck I will see you at the meeting. ;-)
Greencruiser, these are new ubolts...just too dang long.
Anywone have a measurment on the OME rear springs?...Either size...
Thanks,
Thanks Mustard....
Does anyone have an idea about how much thicker the OME heavy duty rear spring packs are in comparison to the Medium?
