Started rebuild on knuckle yesterday. When I disassembled tie rod and cleaned it up I found a spring hanging loose on it. I checked the other end on the drivers side and noticed the loose spring there as well.
What's going on with that spring? Is it supposed to be in that groove? Is it broken and need replacing?
So far the job is going okay except for couple studs on knuckle arm that are unmovable at this time. Sprayed with penetrating oil in hopes of them loosening up. The other two came out with the double nut method. Maybe I'll need to get a stud remover. I'll try again tomorrow and see what happens.
Thanks for any thoughts on the tie rod.
