Spring Install Help-Jack Stand Location
San Diego
I'm trying to understand properly before tackling the spring install. In this excerpt from SOR's site for OME install, it mentions placing the jack stands behind the control arm mounting points. Do they really mean in front of the control arm mounting points? I see no space to place the stands behind the mounting points. :confused:
FRONT SPRINGS AND SHOCKS.
Step 1:
Make sure the vehicle is parked on a flat paved area. If doing the front suspension first, block the rear wheels. Jack the truck up using a floor jack placed under the front axle. Now insert the jack stands to support the frame on each side, right behind the front control arm mounting point. Do the driver side (DS) then the passenger side (PS).
Do not remove the wheels at this point. Unless you have really big jack stands the wheels will settle back on the ground.
http://sleeoffroad.com/technical/tz_ome.htm
Loppy and I just completed this lift on his 93. We were about put the jackstands behind the lower cotnrol arm mounting point, but it seemed that too much engine and frame was hanging out in front of those jackstands. We placed them up in front, closer to the bumper and everything worked out just fine. Franky, once the springs and shocks are on, the wheels can be put back on and the vehicle lowered to make it mroe stable. Then you can change out the steering stabilizer and deal with the caster correction busdings at that point.
Good luck, it is not that difficult at all !!!
I have not done springs but I have used that spot for jack stands before, just aft of where the front control arms meet the frame the control arm brackets and the frame make a bit of an inverted valley for the stand to rest in.
be aware the rear is going to unload quite a bit as the jack is let down because the fulcrum is so close to the middle.
