Spring hanging through frame??
Whitefish, MT
Anyone seen this before? This is the back of the rear spring, the rear of the front spring is the same. Recently bought and going through every inch. I’m assuming there’s a sleeve in there but still... it’s a soa on 37’s, it’ll be used road and trail. Ordering new hangers now..
That’s what some kits do for a shackle reversal on the front. I can’t remeber which brands, but it’s usually to keep the height down when going through the frame.
That looks pretty high In the frame, but without knowing how well it was welded or sleeved, hard to comment much on safety/structural.
yeah not a lot of room for shackle movement. if your springs are totally flat at normal stance though it’ll be ok because the spring will then shorten with flexing or dropping. problem is then you loose the benefit of shackle reversal as the axle will still move forward with each droop and flex too
