Spring bushings
fort smith, arkansas
Hey guys. Having a little trouble matching some spring bushings. This is for my 75 fj40. It has skyjacker springs and HFS shackles. The shackle to frame bushings are the normal ones that ccot sells. The lower bushings however have a thick rim on them. About twice what the upper bushings are. I’m having a hard time finding these, I’m sure I’m missing something obvious here. Anyone happen to have the a part number on these? Battery died on the harbor freight measuring fork sorry.
Specter has a pretty good chart for selecting poly bushings:
I could have sworn they had a great selection of rubber leaf spring & hanger bushings, but I am not finding any rubber options....
Thanks I’ll look through and see if I can spot anything
You can buy them from Skyjacker
Skyjacker provides zero information on their bushings on the webpage. They certainly fit the spring eye, I assume they are either for 5/8 bolt or smaller, in which case I’d just need a steel sleeve. Ganna bite on them and report back.
Those thick ones look like the bushings skyjacker supplies. Last year I switched to skyjacker springs and remember their bushings shoulders being thicker then the ones I got from CruiserTeq.
thanks, i grabbed a bag last night off their site, ill measure them and repost with the info when they come in. i know several other people running this same suspension combination im sure it will come up again at some point.
