SPOA knuckle turning
Central Alabama
Website
www.trailwerx.com
I need to cut and turn some knuckles for a spring over, was thinking of building a jig so that I can do it in house easily, I was thinking of a base plate with 2x4 box tube stands notched to hold the housing, then weld a plate where I can tighten it down with U-bolts.
Never done this before, so do I just set the pinion parrallel with the ground then turn the knuckles 6 degrees back then weld back in place?
Jason
assuming a soa with stock 40 springs and a shackle reverse in front you are safe with the following
set on jackstands( level left to right) , use third jackstand to set pinion at 8*
set new perches on at 0* or level ( you are aware the pass side perch requires cutting to get it to sit on housing nicely) , tack em.
cut ball ends with rented pipe cutter, easy just gotta clean all the stops, shock mounts, and brake line tabs off.
rotate driver side to 4 or 5*( top of ball toward rear of truck)
rotate pass to .5* less than driver side.
weld em, weld brake, shock, and steering stops back on, put under and set vehicle down to verify pinion angle then burn the perches home.
trust me grasshopper.
Peesalot, what is the purpose of rotating the passenger side knuckle ball end .5* less than the driver's side?
caster split so it dosnt follow road crown as much
Ok, I am a new to Landcruiser and all trucks here so excuse me if you find this wuestion stupid. In order to cut and turn, do you need to completly take apart the axle?
You don't have to but it helps. I have heard of people doing it with everything still connected and just the tires off but I'm sure it would take the same amount of time because you have to deal with all the stuff in the way.
That's interesting about the castor split. I didn't do that and it goes perfectly straight on a flat road but on a road where it slopes it definitely goes off the side slowly. Would it turn slightly on a flat road?
Cutoff wheels are nice.If ya get a couple big ones, you can leave all the steering stops and such.Watch your fingers.Just did it last week.Showed some jeepy guys the cut and turn.They liked.
I just mirrored what the factory set the caster to. It was .4* diff when we disassembled it so we just rolled em back the same amount maintaing the diff set in at the factory. Goes straight on all roads. Only thing I think is noticable is at freeway speed it is just a hair tighter and quicker steering left than right just off center, after initial wheel movement it feels same either way.
