kcustom73
Stretched it...
I've done all kinds of work to the 40 over the winter and at one point I had to take the shift levers for the transfercase/np203 doubler off. Having put everything back together to take it for a quick spin yesterday, started the truck and got some grinding coming from one of the cases. Playing with the levers (twin stick setup on the Toyota case) I got the grinding to stop. I put the tranny (4L80e) in drive but I have no movement in the driveshafts. I think the case (splitcase from 88FJ62) is stuck between 2wd & 4wd? Is this possible?
I'm going to lift a tire on the back and see if I can turn it slowly and see if I can get it to go into gear (2wd). I'll drain the oil and see if anything shows up. I'm hoping the grinding didn't cause any damage. What do you guys think?
