split t/c issues!
Boulder, CO
81 fj40 with an sm420 mated to the stock split-style t-case using the ~5" AA adapter. I bought the twin stick kit from AA that supposedly would bolt right up considering my configuration. I got the kit and it is not designed for the larger adapter or the split t-case. Does anyone know where I can get a kit similar to this that would actually work?? I am considering modifying the stock linkage, but if there's an easier way to do it or a kit that would work, I'd probably go that route.
One other thing... my t-case really doesn't like shifting into 4wd or from lo to hi. I went wheelin for the first time last weekend and it was a bitch to get it back into hi when finished on the trail. Finally my buddy got it dis-engaged after driving quite a ways. Tonight I was messing with the linkage kit and put it into 2 lo again and now it's stuck! Any ideas on how I can go about getting this t-case to work more smoothly and get it out of lo? Do I need to grease something on the t-case or is something messed up inside that I'm not yet aware of? Thanks in adavnce for help.
ha ha ha! I wouldn't do that to Mark, he's been very helpful with my post purchase questions and it is an old truck, so stuff is going to break and get worn. It was very tricky to get back into hi after this weekend's trail ride, but it did finally go. What's even worse is you don't get any leverage on it b/c there's no t/c linkage at this time, which is what I was trying to fab up with a friend last night, and as a result it got stuck. I might have to post in the 60-62 forum since most guys with 40's don't have the split t-case.
Anybody have any input on this? Is there a trick to getting the split case out of lo and into hi or am I looking at a bigger issue here that would require a rebuild possibly ? I tried rolling backwards, forwards, in gear, in neutral, etc but with no luck. Seems to me like there should be some sort of trick to this and I don't know that trick! Help!
I would try to determine if the resistance to shifting from hi/lo is the TC or the linkage. This way you could know which may be the culprit and which way to go. Can't help on the linkage question.
May sound dumb but could your TC be under a bind? Meaning different size tires front/rear. Just a thought...
I'm going to check my tire pressure on all wheels tonight and see if there is a difference. There shouldn't be, but it's possible. When the lever on the t-case is pushed all the way towards the drivers side, I'm in lo. It *should* pull back to the passenger side and go into neutral, then into hi gear. When I do this, there is no click into neutral, rather the lever just pulls back easily, but never clicks into neutral, or hi.
It would seem likely that having linkage would at least get me some leverage, but since I don't have any I'll need to figure out how to get it back into hi for the time being, then address the linkage situation once I figure out how exactly to get between lo and hi easily.
FIXED. After combing this forum for several hours, I ended up spraying some PB blaster at the pivot point on the t-case where where you go from hi to lo. After working it for a couple minutes, I realized that I could pull that lever up. Bingo. Once you pull it up it moves in and out of lo-neutral-hi like butter!
Now, to figure out the linkage part of it... This should be fun.
