Spindle Bushing ???
The OEM spindle bushing that came with the truck originally can be sourced as an OEM part. It is not the roller bearing style in my thread you referenced; it looks exactly like the one you probably have in your current spindle.
If you want the roller bearing style one, you need to buy the entire spindle assy. And if you screw one of those up, the roller bearing style bushing is non-sourceable. You would have to re-buy the spindle.
Clear as mud?
:p
Clear as mud?
:p
hmmmm, i did not know that! Thanks for letting me know. I was considering switching over to the roller bearing syle bushing. :hhmm:
That will require new spindles.
I was aware of that. With right at 210,000 miles on the originals and getting about time for a front axle rebuild again, i was contemplating whether this is an upgrade or not. I know from previous threads that Robbie has a set that he is either running or going to run, and i believe i remember a few others saying they were switching. :hhmm:
clear as mud. :crybaby:
I have 122k on my rig, should I replace the bushing with my axle rebuild?
you shouldn't have to. I have been happy with mine, however a front axle rebuild is near and i'm starting to feel/hear slop in the front end even after i have inspected to check that all wheel bearings are tight.
There has been some discussion whether it's an upgrade to go to the spindle type bushing. I think the jury is still out on it. :hhmm:
Make sure your steering arms/ trunnion bearing caps are tight... Just a thought.:meh:
Just to clarify.
There is a brass bushing style spindle (original Toyota part) ...
and
There is a needle bearing style spindle (upgraded Toyota part)
-B-
Just to clarify.
and
-B-
Correct. I miss-typed late last night.
