Spindle Bushing Question
Ok... I have the front end apart.. putting back together with all of Cdans parts.. and the bronze spindle bushing on one side just spins freely:doh:... I was under the impression that this was supposed to be a tight fit..like the other side.
Now my question is can I put this back together with the play in the one side bushing or do I need to wait till I can get a new bushing from the dealership:bang:?
The bushing fits in and you can spin it around on the spindle.. I would say there is a little play, will this cause problems?
Really wanted to finish this today.
No, the bushing is supposed to be a tight press-fit into the back side of the spindle. Either the bushing or spindle is toast.
When you finally get the correct fitment and press them together, make sure you do a test-fit of the Birfield into the new bushing. If it's too tight it will sieze to the Birfield and spin it in the spindle again.
Ditto - sorry for the news but you need a bushing. The good news is this will cure it because the bushing is softer bronze and when it spun it damaged itself vs tearing up the steel spindle.
DougM
delearship
Yikes...Called the delear this morning and that bushing is $79 bucks man along with not letting me finish the front end yesterday it hitting me for a chunk of change for a little piece of brass. Does this part fail often or am I just lucky? Might have to give Cdan a call.
DougM
Bad news, the bushing can damage the spindle, I have seen it several times. I always install bushings with ether loc-tite stud & bearing mount or high temp epoxy, like JB weld to prevent them from moving.
This is a pic of one of my spare mini spindles, the bushing has very little wear and the spindle hole is very egg shape. I wouldn't have a problem with running this spindle, would epoxy the bushing in. Have never tried this on an '80, but have with great results on minis and '40's etc.
pieces of harder material can embed themselves in the soft bushing causing wear. my cv joint shaft had score marks where it runs in the bushing. on closer inspection there was small silver shards of metal embedded in the bushing. not really related to your loose bushing issue though..
Not what I wanted to read right after I bolted up the front of mine with all fresh bearings and ONE new spindle. Not that I could have afforded that second new spindle...but maybe I would have atleast put some JB weld on it.
BTW, how come the new spindle has roller bearings in it? I like that it does...seems better. But is that why it's $250 bucks?
