Speedometer
Salmon Arm B.C.
My speedo has quit.:confused:
Searching the forum I have learned when the speedo starts screaming and bouncing it needs cleaning a lubricating. Well its to late for that my needle has snapped off.:whoops:
Can the needle be replaced? If so where do I get one?
Or should I try to source a new guage cluster? Maybe I should just build a new one? I am no longer using the ammeter or oil pressure guages anyways.
Advise???:o
I haven't researched the 73 and newer speedos, but I can tell you that NOS for the 72 and older is obsolete. When they were available, they were ~$200, so finding a good used one was never a bad idea. From time to time they show up in the Sale section here, and on Ebay.
Hth
Mark A.
I went with the replacement instrument cluster plate from MAF, and then put an aftermarket speedo in. I had to remove the speedo cable and put on a sending unit, but it works just fine.
What sending unit did you use and where did you get it?
Autometer Model 5291. I picked it up at a local hotrod shop. It works with both digital and analog speedos. You will need to fabricate or have someone else fabricate a key to fit into your transfer case. I just cut off approx 3 inches of the old speedo cable and used it.
