Fixed mine all up. It was indeed the speed sensor on the transfer case.
After I made sure the connections at the speed sensor still had good contact, it still was a no-go. The speedometer and odometer were still dead.
I then removed the speed sensor and took into the lab here at work. Since it is a sealed unit, I had nothing to lose and soaked it in acetone. I figured a thorough cleaning would help something out. Actually, I was hoping that some of the acetone would creep its way into the housing and dissolve some contaminants away from some critical contact point. I did not totally submerge the unit. Only the metal portion. I barely left plastic portion out of the acetone. I forgot exactly how long I left it in there to soak. I'd guess a couple hours or less.
I then took the speedsensor out and gave it a good swab cleaning. It was pretty filthy. After a thorough cleaning, I put it back in the acetone to soak a few minutes more. After a few minutes, I took it out and let it dry for the remainder of my work day.
After work, I reinstalled the speed sensor and it still a no-go! Seeing this I called Cruiserparts the next morning and ordered a used speed sensor. Its just my luck!!! After I ordered the speed sensor, that same day, on my home from work the speed sensor started to come back to life. It was erratic the first day or so, but gradually would stay on longer and longer. After a few days, it did not give me a problem anymore, and have not had a problem since. Its been 3 weeks without a problem since the cleaning.
