Hi everyone — we’ve developed a new CAN bus speedometer calibrator. The GX460 version is the first of many vehicle-specific units we plan to release.
We are pleased to bring you this fully plug-and-play Lutz Auto Speedometer Calibrator. Simple up/down buttons are used to change the speed calibration - No complicated dip switches, computer apps, or programming to deal with. This kit is designed for easy plug and play with 2010-2019 GX460s meaning no cutting, splicing, or wire modifications. After installing and calibrating it, you will forget that it exists! Ships quickly from the central coast of California.
www.lutzauto.com
Lexus GX460 Speedometer Calibrator/Correction Device | Lutz Auto
The Lutz Auto Speedometer Calibrator is designed to calibrate your GX460 speedometer to display the correct speed, compensating for any modification that affects the speedometer calibration (ie. tire size). This will also update the rate of the odometer to match the corrected speed. Simple...
www.lutzauto.com
