Speedo sensor Test
Tapage
Club 4X4 Panamá
Panamá
Website
www.4x4panama.com
Hello all folks .. does anyone have an idea how to test the speedo sensor .. mine stop working, so I get another used speedo but that did not work too ..
thanks !
David
Don't you have the FSM?
I'm pretty sure there's a bench test for it: Hook a multimeter up to two of the pin connectors and look for four pulses per revolution, or something like that.
Curtis
Nop .. I don't have the FSM .. can you be so kind or someone else to provide the test procedure . ?
thanks !
David
big thanks dude ..
What I'm catching from the FSM it's in the harness with the key ON you should have constant 12V in terminal 1
main.php
and ground in the terminal 3 .. so that means the speedo get ground throught the terminal 2 for times per revolution ..
thanks ! big thanks !
David
