- Thread starter
- #21
Curiously watching this thread. With 35s, the offset is more than I like. I find myself driving faster, but I'll likely adjust in due time. Still interested in a possible fix, and I don't mind cutting and splicing as I trust my wiring work. Some of these PnP harnesses may invite some of their own vulnerabilities.
Part of the reason is that LX has other systems reliant on CANBUS speed, namely the AHC ECU. It should be lowering the suspension for freeway speeds at ~62mph, but it's currently happening closer to 70mph. As I rely on this behavior when towing, for the side effect of dynamically increasing weight distribution hitch tension at higher speeds for more stability. I've had to adjust my hitch head for more static tension.
I don't think this device will resolve the AHC speed-related issues but I'm not 100% sure. I also don't think it'll correct for any other systems (LC or LX) which rely on the vehicle speed for the same reason. Here's what I see for the LC...
Wires in question on the LC are violet and black and are pins A25/A26 in the EWD going into the Combination Meter Assembly, according to the PDF I linked and to the EWD. These same violet/black wires exist on the 2013 LX though they are pins A36/A35 respectively. (Note I assume this would be the same for all 2008-2015 but would need to browse all the diagrams to confirm).
The CAN-H/CAN-L wires track back to a junction which connects the network ECU, the main body ECU, and the ECM. From what I can tell this is intercepting the CAN signal and re-writing it before it goes to the meter. Unless the meter is sending the signal out to AHC, or unless this is generating a CAN message and sending it backwards up the chain to the network ECU, it's only being used to change the display.
Of note the Suspension Control ECU is separate from the Skid Control ECU on the LX. I suspect for AHC you need to "trick" the Suspension Control ECU, though I'd agree that if all the other ECUs are using their speed readings from the Skid Control ECU then you could probablyk achieve what you want by adjusting the input signal at that source.
From the PDF:
2013 Toyota LC:
2013 LX 570:
