Speed Sensor Compatibility?
Prescott Valley, AZ
I still have the CEL that translates into a bad #1 speed sensor.
I see a lot of people in the parts section getting rid of parts for early model 80s like 93-94....
Do I need to find a 95-97 specific unit only - or would the speed sensors be the same in any 91-94 trucks?
Does anyone have a picture of what and where the #1 speed sensor is? I'd like to at least take a look at it to see if its caked in mud or loose or something first.
Check your FSM but I am pretty sure the #1 speed sensor is the sender on the transfer case. Check the wiring connection and the wires going to the harness.
CruiserDan can tell you if the p/n is the same between those years.
-B-
If it's the sender at the transfer, it is the same from 91-97.
Does anyone have a picture of this sensor on or off the truck?
No FSM? :confused:
Well, one of them (don't know if it's the "#1" one :rolleyes:) is in line with the speedo cable as it mates with the transfer case on the driver's side US. About the size of a "D" battery, with (duh) an electrical connector coming off of it. They do indeed get fouled and fail on 91-92's. When they do (again on a 91-2), the cruiser control won't work; how's yours?
Curtis
