Specific Driveshaft question
Opelika, AL
I was under my truck today spraying all the bolts with rust eater to prepare for my lift and driveshaft removal when I noticed something on my driveshafts that I didn't pay attention to earlier. All the post and things I've read about driveshaft removal support the fact that it's a 14mm bolt head and you need to turn the bolt instead of the nut. Then I looked at the front and rear driveshafts closer as I sprayed them with the rust eater. Where they connect to the TC there are bolts with rounded heads which makes sense because with the tiny space between there you couldn't get the bolts out.
My question is are these bolts stuck in place? :confused:
They have to be or am I missing something.
It will be a problem if they move while I'm trying to tighten the driveshaft back up.
I believe it is the TC side which is just nuts you remove. You'll get nuts and washers off the TC side and nuts, bolts, and washers from the axle side.
As mentioned before in other threads the nuts have a barb(or similiar) to hold them in place. What holds the nuts on the TC side in place. Split or Lock washers?
All the washers on both ends of my driveshafts are split lockwashers. The TC drive flange has studs pressed into it with nuts and split washers. The diff end has bolts with nuts and split washers. I should know--I've only removed the front one about 4 or 5 times.:rolleyes:
I think you may be confusing the control arm bolts and nuts with the driveshafts. The control arm nuts have ridges to bite into the axle bracket. You should turn the bolts when removing the control arm bolts from the axle end of the control arm. And the control arm bolts are much, much bigger than the driveshaft bolts.
Does that help?
Does that help?
Yeah, maybe my memory does deceive me but I could have sworn that I read to remove the nut instead of the bolt on the driveshafts too. Everything's good about the driveshaft though. I was just curious. Thanks everyone!
You mentioned the control arms Lugboot which I will be taking them off soon too. On the axle side you loosen the bolts but the frame side you turn the nuts right? I'm pretty sure that's right.
Yes, I think you're right. It's been almost a year since my arms were off, but I do think the frame end is opposite from the axle end. Turn the bolts on the axle end, turn the nuts on the frame end. The frame end has plate washers under the nuts. Just checked the FSM.
