Speaker trouble shooting question.
My front door speakers are not working at all. No sound.
The back seat speakers are working.
The dash tweeters are working.
Where should I start looking for the problem?
Could it be a problem with the factory amp?
I have adjusted the sound every possible way on the factory head unit.
As always, thanks for your help.
Aye, check to make sure the speakers are there. After that, check the connections both going to the speaker and to the amp. If those seem good and still no sound, I say fxxx it and buy a set of 30-50 dollar aftermarket speakers, some speaker wire, and be done with the stock ones.
the speakers are prob shot, my 96 was raised in CA, 161k, everything is very clean, BUT the speakers were amazingly rotted out and dried. the stock LC speakers are just of horrible, horrible quality. do yourself a favor and replace the front and rear doors, keep the rear sub in place and remove the tweeters. I did this and wow, what a difference. There are lots of threads on replacing speakers here.
Has anyone ever seen seperate tweeters in the door covered in brown cloth? They look like they might be stock but I have never seen another cruiser with them. Mine is a 1994.
The reason I haven't replaced the speakers yet is because I want to put in a component system and replace the ugly cloth covered tweeters in the door just below the window.
tweeters ln the door cards are aftermarket. there are small tweeters in the dash, but no cruiser ever came with components. i just replaced my fronts with some pioneer cheapie 6.5"s. disconnected the factory amp and sub...sounds much better. next to go be replaced are the rear doors, and put some 4" cheapies where the dash tweeters reside...
Well, that's good to know.
Someone did a good job of making the aftermarket tweeters look stock.
The problem is the cloth they put over them is now faded and worn.
I hope the hole they drilled in the panel isn't larger than most aftermarket component speakers tweeters.
I won't be happy until I get rid of those cloth covered tweeters.
