Well, I spent the day swapping my old stereo into my new truck. All I swapped were the head units, and I added the box that interfaces my iPod with the head unit. Yes, that took me all day, including the repair of the instrument screen I manage to break in the process of cleaning it. D'oh. There's a lot of stuff in there, and I figured I'd clean all the instrument connectors while I had the dash apart.
The deck I'm using is a Panasonic DEH P4500 with the Panasonic CD-IB100 iPod interface.
I ran all four existing speakers off the deck. This deck has two amp outputs, too, so I ran the RCA cables for potential amps, and coiled them out of the way for now (this way I don't have to pull the deck in order to add amp(s) at a later date).
As the truck sits right now, it has a 6" Boston Acoustics speaker in each door. The right rear one is dead (I checked the connections, and it's the speaker that's kaput). The factory dashboard and cargo area speakers are still installed, but not connected to anything.
Here's the thing; even with only three door speakers, it sounds great! It sounds as good as my previous set-up, which integrated an external amp for the rear speakers. I'm sure the superior insulation in the Land Cruiser, as well as the lack of a convertible top, has contributed to the enjoyable sound.
Of course, replacing the dead speaker is the next thing to do, so the deck doesn't run unbalanced.
Now, I have a pair of 6x9 speakers sitting here, and an amp I used to drive them in my last truck. What I'd like to do is install the two 6x9s in the cargo area and drive them with the amp. At this point what I have in mind is building them in to my storage box.
What should I do with the amp? Could I run the amp in low pass mode and use the 3-way 6x9s as ersatz subs?
Should I just not use them, and maybe, if anything, run a small (10" or 8") sub off the amp?
For you experts, the amp is a Kicker Impulse 352xi, which is 50x2@2ohm, or 100 bridged mono.
I'm really a novice with car audio, so I'm open to your suggestions....
