Since I still haven't been able to get my hands on any of the '97 LC's FSM's or atleast the EWD....I'll pose this question to the crew.
How are the speaker wires run in terms of their path from the harness plugs at the radio, to the amp, and then on to the respective speakers?
If when using the metra 87-up harness adapter that bypasses the amp that sound still gets to the speakers, then how are running into the amp?
Better yet, only 4 channels are running over the oem harness to the amp (Front L&R, RearL&R). So how are the front dash speakers tied in, and the same goes for the rear cargo roof speakers? I've read that the rear speakers are tapped off of the runs to the rear doors, but when examining the rear door speakers, only one set of wires comes in, and nothing off of the speaker back to the door. usually I've seen that done when no active network device is used to split the signal.
Same goes for the front dash speakers, because I know they come right from the amp area.
Last question: what happens to the load (if still using the OEM Amp with integration harness) if one just unplugs the front dash speakers? Does that recover some load back to be applied to the front doors only?
Thanks for your help!
