Don't use aftermarket ignition parts. The 3FE will spit them out.I have a 92 FJ80 3FE. What plugs and wires do you use? Should I change the distributor and rotor with it. I have hade the cruiser for over 10 years and have never changed it.
ThanksDon't use aftermarket ignition parts. The 3FE will spit them out.
OEM plug wire set 90919-21503
OEM plugs 90919-01091
OEM distributor cap 19101-61240
OEM distributor cap gasket 19127-61240
OEM distributor rotor 19102-61240
Not unless the engine stops running.Should I change the distributor assembly?
They allow fresh air to be drawn through the cap to prevent condensation/rust/corrosion.What do the 2 vacuum lines that go to the distributor cap do?
No just wondering.Not unless the engine stops running.
Is there something troubling you about the distributor?
Check vacuum on EVERYTHING. Replace any rubber pieces that are hard or brittle. Your motor is very susceptible to problems with un-metered air entering the engine, including the oil dipstick, oil filler cap, and intake hoses. Also, make sure your valves are adjusted properly (every 15k miles, per the FSM).Replaced my plugs and wire waiting on the distributor cap and rotor to arrive. After replacing the plugs and wires she still has a little miss every so often. Could that be from the distributor cap and rotor?
