Spark Plug Install with TRD S/C
Purcellville, VA
I plan to put new plugs/wires/cap/rotor on my rig in the next few weeks. I have a S/C with that large aluminum tube running across the valve cover from the intake manifold (see pic below).
Q's:
1. I plan to replace the black hose (90 degree sections) connecting the blower to the intake. Any idea where to source that from or can I get it from local Napa/Fastenal, etc? I haven't measured, but it looks to be about 4".
2. Can I unbolt the tube that connects to the intake and pull that off without issue? Is there a gasket in there that I will need to replace? If so, does anyone have a part #?
Thank you.
img_1577-jpg.1403800
1. Get Silicone Hose on Ebay if you want best performance.
2. Unbolt Aluminum Tube Connected to Intake.
Do one plug at a time if your going to replace the wires.
*If it won't go back together send me a PM and I will help you get rid of it.
I sourced the replacement silicone hoses from Amazon. They are both 3", one was a straight hose on the intake intake side and a hump hose on the supercharger side as the alignment was not straight across and the hump allows for the variance. There is another smaller hose, may be 1.5", off the bypass valve that I wish I had replaced as well.
Amazon.com: HPS HTSC-300-BLK Silicone High Temperature 4-Ply Reinforced Straight Coupler Hose, 75 PSI Maximum Pressure, 3" Length, 3" ID, Black: Industrial & Scientific
Amazon.com: HPS HTSHC-300-BLK Silicone High Temperature 4-ply Reinforced Straight Hump Coupler Hose, 60 PSI Maximum Pressure, 3" Length, 3" ID, Black: Industrial & Scientific
Thank you for the links to the hoses.
Is the throttle body gasket the gasket between the intake and the metal tube going across the valve cover? I thought that was down underneath the intake? Not sure why I'd need a TB gasket?
It's because it's the gasket used. The throttle body used to be where the "tube" is. So now your truck requires (2) throttle body gaskets. One where it was and one where it is.
i reused my TBG... only so many times though. Eventually it's smashed nice and flat and you will need a new one.
Not sure how I'll get the 1.5" hose on this bypass. I haven't looked too close yet but maybe I can unbolt the bypass. Maybe?
Also had an issue getting the plugs out of the head. Many of you probably figured this out already but I cut a small section of 1/2" hose and jammed it into my socket. Easy peezy.
Holy cow. That little SOB stands in company with the PHH and the fuel filter. Wow. I had to unbolt the bypass, install the hose and then reinstall it onto the blower.
For anyone considering doing that little hose, think twice.
On a good note, I got the plugs, wires, cap, rotor and all the vacuum lines changed out. Looking forward to firing it up tomorrow.
This is great info ! I have been thinking on replacing mine as well.
After I looked at those links I wonder if there is a 90 degree one piece that would work (?) that would make the set up simpler
If you find a one piece, make sure it has a wire reinforcement or similar. I tried a one piece silicon hose in that installation and at idle, the engine vacuum pulls it almost flat. Under boost, of course, it's fine.
