Spare Driveshaft Storage
MD
What all containers does the collective use to store spare driveshafts (not axles)? The flange diagonal measurement is about 5". That's a whopper of a tube/pipe. I was thinking of a thin walled pvc, but the largest size Home Depot carries is 4".
All suggestions are welcome.
Thanks, Dan
In my rig, just looking for a solid, easily movable setup that I can batten down for the trail. I heard someone used old rocket launcher tubes...
I got low clearance, so under the frame would cause more problems than solve.
I have a couple surplus rocket ammo cans. The rear shaft fits as is while the front shaft needs to have the slip joint pulled to fit. Plus there is room for front axle shafts and birfields. I wrap them in stretch wrap to keep the noise down and for protection of the axle shafts. Handles on top and side for tie down straps. Available at most surplus stores....
Nick
not UNDER the frame... strapped to the inside of the frame. I use large hose clmps, but zip ties, a tie down, or some other creative means will work too. I used keep a spare drive line and tie rods there before I replaced all my stock stuff.
-Dustin
