- Joined
- May 24, 2015
- Threads
- 32
- Messages
- 359
Only when freezing temps...lets say -5C or colder. 23F or colder.
'85 pick up... whenever it's -5C or colder out if I go over a pot hole or rapid bumps through a wash-boardy-non-maintained-intersection it sounds like someones rapping the frame rail with a hammer right below my driver side floor pan. Almost sounds like a hammered out ball joint in a vehicle that uses ball joints... clunk CLUNK as it drops into the hole then hammers back as it comes out of the hole.
If I rally it enough over enough wash board intersections and pot holes it doesn't make noise anymore. At non freezing temperatures there is no noise.
New wheel bearings. New knuckle bearings. New leaf spring bushings. New bilstein 5125's. High steer, all new tie rod ends. Brass bushings in the spindles are mint. New ubolts. New centerbolt. No cracked leafs. They are all pro lift springs, full military front wrap half or 3/4 rear wrap or whatever they call it. Leafs probably at least 15 years old by now. All the knuckle hardware, U bolts, shackle bolts everything all checked and tight.
If I'm in a drivethru and I pull up to the next window and lightly touch the brake I hear the slightest clunk...at any temperature.
Truck rides like a cloud of titties... Super soft and plush. When it's clunking I wouldn't say there is any loss of function of the suspension...just noise.
I dunno... only seems to be on the driver side. Do leaf springs clunk when frozen? What else can be making noise? Literally the entire front end has been re-manufactured except the 15 year old leaf packs.
I'm kinda thinking maybe the bilsteins have enough rebound pressure/gas charge it slightly unloads the leaf pack and freezes then it takes some hammering sessions to settle the pack back together? Or when I launch it to the next window at the drive through the pack unsettles a bit and when I touch the brake it settles the pack back together?
Worn out leaf springs?
Anyone have a random frozen clunk or anything like I'm describing here?
On a summer day this thing is dead silent flying through a wash board intersection. -5c sounds like the front end is about to have a yard sale of parts through the same intersection.
