Sounds...clutch or front diff or ???
Virginia
My '71 just started losing clutch fluid, the 4wd light doesn't come on when engaged and it makes a slight winding down noise when I slow down out of gear or clutch depressed. Before, it would be totally silent if the clutch was depressed or if it was out of gear. Well, as you know...not totally silent...but no winding down sound.
Any ideas? I'm worried that either the clutch is dying, or the 4wd won't disengage. I know there's a leak somewhere...as the fluid level is sinking...but would a leak cause the winding down sound?
I wanted to get some ideas from the group before I bring it to the mechanic.
Three distinct problems. Could be related, but probably not.
If the hydraulics are weak [beyond losing fluid weak] then you would be grinding more than usual trying to get into gear.
4wd indicator lights are not necessarily reliable after 35 years or so.:doh: You might have to take it apart and clean it, maybe even replace it.
If you think you might be in 4wd, then that definitely would make a different sound in your powertrain. You can easily check by seeing if you can turn the front drive shaft by hand while the hubs are unlocked.
Hth
Mark A.
Thanks Mark. It was late..and I wasn't very clear, sorry.
I can turn the front drive shaft by hand, it spins freely. The gears shift very easily..or, no harder than they ever have before.
However, clutch fluid is leaking somewhere...but I cannot find the leak. My truck leaks EVERYWHERE...making detection a bit harder.
I have notices that the front end whines on deceleration with the clutch IN while IN Gear and with the clutch out while in Neutral. I don't recall this sound before this week. If the front driveshaft spins, it shouldn't be that 4wd is engaged
What Mark said, and since you leak everywhere, check fluid in T/TC as well as the diffs.
GL
Ed
Thanks much for the replies.
I'll check the fluids first, then clean things up a bit and try to find this particular leak.
Doug
