sound proofing
Eagle, ID
So after seeing https://forum.ih8mud.com/80-series-tech/133959-recipe-quiet-er-cruiser.html sully do his sound proofing magic i decided that my rig could use a little help. I must precursor this by saying that i had no intention to do the job that sully did. I had a leaking sunroof and mildew carpet so i new i was tearing out all my carpet so i thought i would throw down on some damplifier, spectrum, and some overkill.
I tore out all carpet, most of my plastic side molding if nothing else for a really good cleaning. the jute had bad mildew so all of it came out. The local laundromat got my carpet with a little bleach, alot of tide and a big mess it came out looking really nice. I took it back to my house and used our home vacum to get it really really good. I also took some febreeze to it for good measure a handfull of times.
I then took my air compressor and cleaned the inside as good as possible I had to wire brush out a little jute but this step was pretty minimal.
I next did Damplifier on pretty much then entire floor. I follow sullys directions avoiding some areas and doubling up some areas like the front driver and passenger seat areas. I will also use double on the rear wheel wells and most of the rear storage area. The rear always feels like a huge cavern that just echos noise.
I went over the damplifier with overkill in thhigh noise areas. This product is so easy to work with and reasonably priced that i used alot of it on the re-install as well between consoles or tranny covers ect.
Lastly i purchased some commercial grade "felt" that the carpet store said it was used as padding for commercial locations. It was thick, Super dense and seemed like it would hold sound down well while holding up really well to foot traffic. It was 4 dollars a square yard i think i got 20 sq yards wich was WAY too much.
As i reinstalled everything it was the first time my rig looked this nice since i have owned it. I also took this time to remove most of the fake wood and i installed a new Alpine CD deck. It feels like a new rig.
while my rear quarter panels and the front transmission cover were off i put about 5 coats of Spectrum on them to help with the sound. I am not sure if this was the most effective as spectrum is for "structure" born sound. Both of these areas were going to be a pain to put damplifier in so i started here. If i have to go back to the rear quarters and put damplifier in that is fine but this was way easier to begin with.
Here are pics. I know there is not any new information here but i get so much great info off the site that i thought i would kick some love back.
I havent driven it yet but will in the next couple days. I am just finishing up a little neoprene that will go around my shocks. I have a hoop that sits just behind my second row that my shocks mount too. I am tryign to waterproof that better and sound deaden it better at the same time.
Speaking of soundproofing, when I took out the plastic panel on the side in the cargo area, I noticed the only soundproofing and insulation was sheet metal and a little bit of plastic.
I was kinda shocked. It made me want to think of different ways to insulation and block out sound.
I think that is the biggest problem area on a cruiser. Its like a big chamber that just echos sound.
Good work - I Dynamat'd my old XJ after having the six point cage installed and it made a huge difference. Of course...now you can ditch that carpet and Durabak the entire floorpan :D
I did mine a couple of months ago, and I agree, it was worth the effort. Much quieter now.
I used B-Quiet, but I think they're all about the same:
B-Quiet sound deadening material
It was about half the price of Dynamat.
I added some asphalt sheeting from a hotrod shop in each footwell. Helped a little, but I think the aluminum-backed stuff is the most significant.
Questions, what happens when this stuff gets wet? Say in a water crossing or the resent stuck in a rut thread that is like 50 pages long by now. Moldy, resistant? and how about hte application of linex over it? thanks in advance
Most of the brands are butyl backed to foil. Won't mildew because water cannot permeate it.
