NiceThe strips come with adhesive on them, just need to remove the plastic backing and press them on the door.
Thanks for the info. I’m gonna order me a set.
I'm thinking about adding some sound deadening material to my 09 LC. Is this what you used?I insulated my entire floorpan, doors, and rear 1/4 panels with kilmat sound deadening mat. Little to no noise from my aggressive all terrains!
Did you add the sound deadening material you asked about in your August, 2022 post?I’ve got a 09 LC, and I’d like to quiet the noise. Any tips?
After snapping of the window trim end plate on one side (I figured it was retained by a pin similar to the new door seal) I modified the other side by just drilling an 1/8" hole in the plastic piece to accept the new seal's pin.Installed on my 21 LC today. The only difference Toyota/Lexus is that the bright window belt trim on the Toyota does not have a small hole to accept the plastic clip/nub. Since I did not feel like disassembling the molding or trying to pry the cover off, I just neatly cut the top part off and now have the strip connected fully with the adhesive. It looks great to me and what the heck - figure it should do something?
Anyway, no sound improvement as expected, but maybe just classing up the "utilitarian" LC to LX level a bit?
