- Joined
- Mar 11, 2006
- Threads
- 207
- Messages
- 1,937
The rig is a 96 with OME 2.5 and yellow bushings installed per OME instructions. Stock other than that.
I installed a locking front housing and the lift at the same time. I had it alinged after the installation in November 2008.
The truck still pulled to the right after the alingment. So I took it back last week and them rotate the tires and redo the alingment. Prios to this alignment PS toe was -.10 and the PS caster 1.7..
I am concerned that the toe and the caster changed that much in 3 months. I get the toe, a pot hole or something but the caster really shouldn't, should it? Could there be some settling in the suspension/caster bushings that would cause this?
I did the LT bushing and tie rod test and everything seems tights. I don't see any obvious signs of wear.
Final FEA info from 11/30/2008
Caster
DS 2.1, PS, 1.9
Toe 0.0 both sides
Camber
DS .02
PS .04
Final FEA info 1/19/2009
Caster
DS 2.1, PS 1.5
Toe .05 both sides
Camber
DS .03
PS .04
Ultimately, I think I need to pull the arms back off and reinstall the bushings using LT template.
Caster
DS 2.1, PS, 1.9
Toe 0.0 both sides
Camber
DS .02
PS .04
Caster
DS 2.1, PS 1.5
Toe .05 both sides
Camber
DS .03
PS .04
